stereo upgrade posted by reaperz1 on May 28, 2012 at 08:22 PM
amp like the write up says you either have to buy an adapter from Nissan or cut out a piece of wood to hold the new speaker. If you go the wood route which is much cheaper, use 1/4 inch plywood and keep the speaker as deep into the door as you can. To do this I didn't use the plastic mounting ring that came with the speaker. I screwed the speaker directly to the wood. I had a stereo shop remove the Bose system and install new door speakers. Just recently I changed them and found the rubber surrounds pinched from the interior door panel.
